Use this procedure to enable IP multicast route statistics.
When you enable or clear IP multicast route statistics on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
- In the navigation pane, expand
- Select Multicast.
- Select the Globals tab.
- In StatsEnabled, select the option to enable or disable the collection of statistics.
- Optional: To clear the statistics, select StatsClear.
- Select Apply.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
Field |
Description |
StatsEnabled |
Displays whether the multicast route statistics is enabled. |
StatsClear |
Clears the multicast route statistics. |
